Zum Hauptinhalt wechseln
Backbone One Direction Pad Replacement
Was du brauchst
  1. Backbone One Direction Pad Replacement, Unfasten the screws: Schritt 1, Bild 1 von 1
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
    Frag FixBot
    Kommentar hinzufügen
  2. Backbone One Direction Pad Replacement, Rotate the upper cover: Schritt 2, Bild 1 von 3 Backbone One Direction Pad Replacement, Rotate the upper cover: Schritt 2, Bild 2 von 3 Backbone One Direction Pad Replacement, Rotate the upper cover: Schritt 2, Bild 3 von 3
    • Lift up the upper part of the controller.
    • Swing over the upper cover and place it on the controller case.
    • Take care that the interconnecting cable has no tension.
    Frag FixBot
  3. Backbone One Direction Pad Replacement, Remove the protective tape: Schritt 3, Bild 1 von 3 Backbone One Direction Pad Replacement, Remove the protective tape: Schritt 3, Bild 2 von 3 Backbone One Direction Pad Replacement, Remove the protective tape: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable connector.
    Frag FixBot
  4. Backbone One Direction Pad Replacement, Open the ZIF connector: Schritt 4, Bild 1 von 2 Backbone One Direction Pad Replacement, Open the ZIF connector: Schritt 4, Bild 2 von 2
    • Use the tip of an opening pick to open the gray flap of the ZIF connector by pushing it upwards.
    Frag FixBot
  5. Backbone One Direction Pad Replacement, Disconnect the interconnect cable: Schritt 5, Bild 1 von 2 Backbone One Direction Pad Replacement, Disconnect the interconnect cable: Schritt 5, Bild 2 von 2
    • Use your fingers to disconnect the interconnect cable from its connector.
    Frag FixBot
  6. Backbone One Direction Pad Replacement: Schritt 6, Bild 1 von 2 Backbone One Direction Pad Replacement: Schritt 6, Bild 2 von 2
    • Remove the upper half of the left controller assembly.
    Frag FixBot
  7. Backbone One Direction Pad Replacement, Remove the screw: Schritt 7, Bild 1 von 2 Backbone One Direction Pad Replacement, Remove the screw: Schritt 7, Bild 2 von 2
    • Use a Phillips screwdriver to remove the 5.9 mm-long screw which is securing the trigger.
    • The screw is difficult to reach. Insert the screwdriver at an angle of 45 degrees.
    Frag FixBot
  8. Backbone One Direction Pad Replacement, Remove the trigger: Schritt 8, Bild 1 von 2 Backbone One Direction Pad Replacement, Remove the trigger: Schritt 8, Bild 2 von 2
    • Remove the left trigger.
    Frag FixBot
  9. Backbone One Direction Pad Replacement, Remove the bumper: Schritt 9, Bild 1 von 2 Backbone One Direction Pad Replacement, Remove the bumper: Schritt 9, Bild 2 von 2
    • Use your fingers to remove the left bumper.
    Frag FixBot
  10. Backbone One Direction Pad Replacement, Remove the screws: Schritt 10, Bild 1 von 1
    • Use a Phillips screwdriver to remove the four 3.9 mm-long screws.
    Frag FixBot
  11. Backbone One Direction Pad Replacement, Remove the mainboard: Schritt 11, Bild 1 von 2 Backbone One Direction Pad Replacement, Remove the mainboard: Schritt 11, Bild 2 von 2
    • Remove the mainboard.
    Frag FixBot
  12. Backbone One Direction Pad Replacement, Remove the direction pad: Schritt 12, Bild 1 von 3 Backbone One Direction Pad Replacement, Remove the direction pad: Schritt 12, Bild 2 von 3 Backbone One Direction Pad Replacement, Remove the direction pad: Schritt 12, Bild 3 von 3
    • Use a pair of blunt nose tweezers to remove the direction pad.
    Frag FixBot
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
iFixit Mitglied von iFixit
Staff
122 Mitglieder
25.813 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 21
Letzte 30 Tage: 96
Insgesamt: 3,146
