Zum Hauptinhalt wechseln
Backbone One Face Buttons Replacement
Was du brauchst
  1. Backbone One Face Buttons Replacement, Remove the screws: Schritt 1, Bild 1 von 1
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
    Frag FixBot
    Kommentar hinzufügen
  2. Backbone One Face Buttons Replacement, Rotate the upper part: Schritt 2, Bild 1 von 3 Backbone One Face Buttons Replacement, Rotate the upper part: Schritt 2, Bild 2 von 3 Backbone One Face Buttons Replacement, Rotate the upper part: Schritt 2, Bild 3 von 3
    • Lift up the upper cover of the controller.
    • Swing the upper cover over and place it on the controller case.
    • Make sure that the interconnecting cable has no tension.
    Frag FixBot
  3. Backbone One Face Buttons Replacement, Remove the protective tape: Schritt 3, Bild 1 von 3 Backbone One Face Buttons Replacement, Remove the protective tape: Schritt 3, Bild 2 von 3 Backbone One Face Buttons Replacement, Remove the protective tape: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable and the connector.
    Frag FixBot
  4. Backbone One Face Buttons Replacement, Open the interconnect cable ZIF connector: Schritt 4, Bild 1 von 3 Backbone One Face Buttons Replacement, Open the interconnect cable ZIF connector: Schritt 4, Bild 2 von 3 Backbone One Face Buttons Replacement, Open the interconnect cable ZIF connector: Schritt 4, Bild 3 von 3
    • Use the tip of an opening pick to open the gray flap of the interconnect cable ZIF connector by pushing it upwards.
    Frag FixBot
  5. Backbone One Face Buttons Replacement, Disconnect the interconnect cable: Schritt 5, Bild 1 von 2 Backbone One Face Buttons Replacement, Disconnect the interconnect cable: Schritt 5, Bild 2 von 2
    • Disconnect the cable by pulling it straight out the ZIF connector.
    Frag FixBot
  6. Backbone One Face Buttons Replacement, Disconnect the phone connector cables: Schritt 6, Bild 1 von 3 Backbone One Face Buttons Replacement, Disconnect the phone connector cables: Schritt 6, Bild 2 von 3 Backbone One Face Buttons Replacement, Disconnect the phone connector cables: Schritt 6, Bild 3 von 3
    • Use a pair of tweezers to disconnect the phone connector cables out from their sockets.
    Frag FixBot
  7. Backbone One Face Buttons Replacement, Separate the upper case: Schritt 7, Bild 1 von 1
    • Separate the the upper case of the left controller handle.
    Frag FixBot
  8. Backbone One Face Buttons Replacement, Remove the screws: Schritt 8, Bild 1 von 1
    • Use a Phillips screwdriver to remove the three 5.9 mm-long screws.
    Frag FixBot
  9. Backbone One Face Buttons Replacement, Remove the trigger: Schritt 9, Bild 1 von 2 Backbone One Face Buttons Replacement, Remove the trigger: Schritt 9, Bild 2 von 2
    • Remove the trigger.
    Frag FixBot
  10. Backbone One Face Buttons Replacement, Remove the bumper: Schritt 10, Bild 1 von 2 Backbone One Face Buttons Replacement, Remove the bumper: Schritt 10, Bild 2 von 2
    • Remove the bumper.
    Frag FixBot
  11. Backbone One Face Buttons Replacement, Remove the screws: Schritt 11, Bild 1 von 1
    • Use a Phillips screwdriver to remove the two 3.9 mm-long screws.
    Frag FixBot
  12. Backbone One Face Buttons Replacement, Remove the mainboard: Schritt 12, Bild 1 von 3 Backbone One Face Buttons Replacement, Remove the mainboard: Schritt 12, Bild 2 von 3 Backbone One Face Buttons Replacement, Remove the mainboard: Schritt 12, Bild 3 von 3
    • Remove the mainboard.
    Frag FixBot
  13. Backbone One Face Buttons Replacement, Remove the rubber cover: Schritt 13, Bild 1 von 3 Backbone One Face Buttons Replacement, Remove the rubber cover: Schritt 13, Bild 2 von 3 Backbone One Face Buttons Replacement, Remove the rubber cover: Schritt 13, Bild 3 von 3
    • Use a pair of blunt nose tweezers to remove the rubber cover which is placed over the face buttons.
    Frag FixBot
  14. Backbone One Face Buttons Replacement, Remove the face buttons: Schritt 14, Bild 1 von 3 Backbone One Face Buttons Replacement, Remove the face buttons: Schritt 14, Bild 2 von 3 Backbone One Face Buttons Replacement, Remove the face buttons: Schritt 14, Bild 3 von 3
    • Use a pair of tweezers to remove the face buttons.
    Frag FixBot
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
Eine weitere Person hat diese Anleitung absolviert.
iFixit Mitglied von iFixit
Staff
122 Mitglieder
25.843 Anleitungen geschrieben
1 Kommentar zur Anleitung
is there any way to do this without taking apart the entire controller?
Robert - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 15
Letzte 30 Tage: 76
Insgesamt: 3,410
