Zum Hauptinhalt wechseln
Backbone One Phone Connector Replacement
Was du brauchst
  1. Backbone One Phone Connector Replacement, Remove the screws: Schritt 1, Bild 1 von 1
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
  2. Backbone One Phone Connector Replacement, Rotate the upper part: Schritt 2, Bild 1 von 3 Backbone One Phone Connector Replacement, Rotate the upper part: Schritt 2, Bild 2 von 3 Backbone One Phone Connector Replacement, Rotate the upper part: Schritt 2, Bild 3 von 3
    • Lift up the upper cover of the controller.
    • Swing the upper cover over and place it on the controller case.
    • Make sure that the interconnecting cable has no tension.
  3. Backbone One Phone Connector Replacement, Remove the screws: Schritt 3, Bild 1 von 1
    • Use a Phillips screwdriver to remove the two 4.8 mm-long screws securing the phone connector.
  4. Backbone One Phone Connector Replacement, Unthread the phone connector: Schritt 4, Bild 1 von 3 Backbone One Phone Connector Replacement, Unthread the phone connector: Schritt 4, Bild 2 von 3 Backbone One Phone Connector Replacement, Unthread the phone connector: Schritt 4, Bild 3 von 3
    • Use your fingers to thread the phone connecter through the opening in the plastic cover at the right side of the rear cover.
  5. Backbone One Phone Connector Replacement, Disconnect the phone connector cable: Schritt 5, Bild 1 von 2 Backbone One Phone Connector Replacement, Disconnect the phone connector cable: Schritt 5, Bild 2 von 2
    • Use a pair of tweezers to disconnect the first phone connector cable from the mainboard.
  6. Backbone One Phone Connector Replacement, Disconnect the phone connector cable: Schritt 6, Bild 1 von 2 Backbone One Phone Connector Replacement, Disconnect the phone connector cable: Schritt 6, Bild 2 von 2
    • Use a pair of tweezers to disconnect the second phone connector cable from the mainboard.
  7. Backbone One Phone Connector Replacement, Remove the phone connector cable: Schritt 7, Bild 1 von 1
    • Remove the phone connector cable.
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Adriana Zwink
48.052 Reputation
167 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
16.718 Anleitungen geschrieben
4 Kommentare
Where can i buy a new part
reye_s - Antwort
Unfortunately we haven't found any replacement parts yet. If you find a website that offers replacement parts feel free to share your experience with us.
Adriana Zwink -
Where can I find the connector
Big_deppresion_time_14 Xxx - Antwort
My son bent the connector cable. Where do I buy a new one?
Please update as soon as possible!
Krystal Glavic - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 23
Letzte 30 Tage: 133
Insgesamt: 2,407
