Einleitung
Use this guide to replace a broken phone connector on your Backbone One.
Was du brauchst
Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
Lift up the upper cover of the controller.
Swing the upper cover over and place it on the controller case.
Use a Phillips screwdriver to remove the two 4.8 mm-long screws securing the phone connector.
Use your fingers to thread the phone connecter through the opening in the plastic cover at the right side of the rear cover.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use a pair of tweezers to disconnect the first phone connector cable from the mainboard.
Use a pair of tweezers to disconnect the second phone connector cable from the mainboard.
Repair didn’t go as planned? Ask our Answers community for help.
Eine weitere Person hat diese Anleitung absolviert.
6 Kommentare zur Anleitung
Where can I find the connector
My son bent the connector cable. Where do I buy a new one?
Please update as soon as possible!
