Zum Hauptinhalt wechseln
Backbone One Right Mainboard Replacement
Was du brauchst
  1. Backbone One Right Mainboard Replacement, Remove the screws: Schritt 1, Bild 1 von 1
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
    Frag FixBot
    Kommentar hinzufügen
  2. Backbone One Right Mainboard Replacement, Rotate the upper part: Schritt 2, Bild 1 von 3 Backbone One Right Mainboard Replacement, Rotate the upper part: Schritt 2, Bild 2 von 3 Backbone One Right Mainboard Replacement, Rotate the upper part: Schritt 2, Bild 3 von 3
    • Lift up the upper cover of the controller.
    • Swing the upper cover over and place it on the controller case.
    • Make sure that the interconnecting cable has no tension.
    Frag FixBot
  3. Backbone One Right Mainboard Replacement, Remove the protective tape: Schritt 3, Bild 1 von 3 Backbone One Right Mainboard Replacement, Remove the protective tape: Schritt 3, Bild 2 von 3 Backbone One Right Mainboard Replacement, Remove the protective tape: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable and the connector.
    Frag FixBot
  4. Backbone One Right Mainboard Replacement, Open the interconnect cable ZIF connector: Schritt 4, Bild 1 von 3 Backbone One Right Mainboard Replacement, Open the interconnect cable ZIF connector: Schritt 4, Bild 2 von 3 Backbone One Right Mainboard Replacement, Open the interconnect cable ZIF connector: Schritt 4, Bild 3 von 3
    • Use the tip of an opening pick to open the gray flap of the interconnect cable ZIF connector by pushing it upwards.
    Frag FixBot
  5. Backbone One Right Mainboard Replacement, Disconnect the interconnect cable: Schritt 5, Bild 1 von 2 Backbone One Right Mainboard Replacement, Disconnect the interconnect cable: Schritt 5, Bild 2 von 2
    • Disconnect the cable by pulling it straight out the ZIF connector.
    Frag FixBot
  6. Backbone One Right Mainboard Replacement, Disconnect the phone connector cables: Schritt 6, Bild 1 von 3 Backbone One Right Mainboard Replacement, Disconnect the phone connector cables: Schritt 6, Bild 2 von 3 Backbone One Right Mainboard Replacement, Disconnect the phone connector cables: Schritt 6, Bild 3 von 3
    • Use a pair of tweezers to disconnect the phone connector cables out from their sockets.
    Frag FixBot
  7. Backbone One Right Mainboard Replacement, Separate the upper case: Schritt 7, Bild 1 von 1
    • Separate the the upper case of the left controller handle.
    Frag FixBot
  8. Backbone One Right Mainboard Replacement, Remove the screws: Schritt 8, Bild 1 von 1
    • Use a Phillips screwdriver to remove the three 5.9 mm-long screws.
    Frag FixBot
  9. Backbone One Right Mainboard Replacement, Remove the trigger: Schritt 9, Bild 1 von 2 Backbone One Right Mainboard Replacement, Remove the trigger: Schritt 9, Bild 2 von 2
    • Remove the trigger.
    Frag FixBot
  10. Backbone One Right Mainboard Replacement, Remove the bumper: Schritt 10, Bild 1 von 2 Backbone One Right Mainboard Replacement, Remove the bumper: Schritt 10, Bild 2 von 2
    • Remove the bumper.
    Frag FixBot
  11. Backbone One Right Mainboard Replacement, Remove the screws: Schritt 11, Bild 1 von 1
    • Use a Phillips screwdriver to remove the two 3.9 mm-long screws.
    Frag FixBot
  12. Backbone One Right Mainboard Replacement, Remove the mainboard: Schritt 12, Bild 1 von 3 Backbone One Right Mainboard Replacement, Remove the mainboard: Schritt 12, Bild 2 von 3 Backbone One Right Mainboard Replacement, Remove the mainboard: Schritt 12, Bild 3 von 3
    • Remove the mainboard.
    Frag FixBot
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
Eine weitere Person hat diese Anleitung absolviert.
Adriana Zwink
66.974 Reputation
167 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
122 Mitglieder
25.813 Anleitungen geschrieben
1 Kommentar zur Anleitung
Where do I find this replacement part?
pete_r10@live.com - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 50
Insgesamt: 2,036
