Einleitung
This is a disassembly Guide For the nook Glowlight 3
Was du brauchst
This is the Nook Glowlight 3. It features an E-ink display with a resolution of 300 ppi. This device is touchscreen. It comes with 8GB of on device storage. It is wifi compatible
First, grab your Jimmy or any other thin tool and slide it along the edge of the device where the two halves meet, (shown in the picture).
Push firmly until the tool slides into the crack. Then rotate the tool as you slide it down to separate the clips securing the device.
Do this all around the device until the device splits into two halves.
When both of the halves are able to be separated move the back cover aside.
To reassemble the device, push down on the back cover until it snaps into place.
Remove the screws marked in red that secure the system board to the outer plastic.
On both sides, there are two straight and skinny button panels. These control the side up/down buttons. Please disconnect both of these ribbon cables.
Now remove the battery by sliding a spudger underneath the battery and breaking the adhesive.
Remove the rest of the screws connecting the display to the frame. Remember to take out both of the button boards.
Push firmly on the display. Going all around the edges until the display becomes loose. (the screen was already cracked)
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
