Was du brauchst
Remove the air piston and barrel turning part. This is the part you will be working on.
4 weitere Personen haben diese Anleitung absolviert.
4 Kommentare
Excellent guide, thanks for putting it together! We got a brand new Strongarm we couldn’t return so I followed your guide to take it apart. However, nothing was broken.
We noticed the barrel rotated fine when manually pulling the mechanism when the blaster was apart, but it wasn’t rotating when screwed back together. I applied some Super Lube grease to several areas in the mechanism where I thought friction might be introduced and, voila! The blaster fires and slam fires reliably.
Without your guide I would’ve been really stuck, though. Thank you!
You’re welcome!
Thank you! I realized after this that one of my springs was out of place, and so the blaster was not working properly. Thank you for the help!
No problem! Happy to help! :)
