Zum Hauptinhalt wechseln
Barstool Seat Cushion Replacement
Was du brauchst
    1. Barstool Seat Cushion Replacement, Barstool Seat Cushion: Schritt 1, Bild 1 von 3 Barstool Seat Cushion Replacement, Barstool Seat Cushion: Schritt 1, Bild 2 von 3 Barstool Seat Cushion Replacement, Barstool Seat Cushion: Schritt 1, Bild 3 von 3
      • Remove the four hex screws under the barstool using an Allen wrench.
      • If your stool has a backrest, remove it by unscrewing the two hex screws with an Allen wrench.
      Frag FixBot
      Kommentar hinzufügen
    2. Barstool Seat Cushion Replacement: Schritt 2, Bild 1 von 3 Barstool Seat Cushion Replacement: Schritt 2, Bild 2 von 3 Barstool Seat Cushion Replacement: Schritt 2, Bild 3 von 3
      • Remove the four Phillips screws.
      • Grab and lift the metal frame and push the seat out at the same time.
      Frag FixBot
    3. Barstool Seat Cushion Replacement: Schritt 3, Bild 1 von 3 Barstool Seat Cushion Replacement: Schritt 3, Bild 2 von 3 Barstool Seat Cushion Replacement: Schritt 3, Bild 3 von 3
      • Remove the staples around the bottom of the stool.
      • Lift the bottom fabric off.
      • You can save or replace the bottom fabric.
      • Remove any remaining staples.
      Frag FixBot
    4. Barstool Seat Cushion Replacement: Schritt 4, Bild 1 von 3 Barstool Seat Cushion Replacement: Schritt 4, Bild 2 von 3 Barstool Seat Cushion Replacement: Schritt 4, Bild 3 von 3
      • Remove the board from the foam and fabric.
      • Save the board.
      • Take the new foam, lay it flat on a surface, and place the board in the center of it.
      Frag FixBot
    5. Barstool Seat Cushion Replacement: Schritt 5, Bild 1 von 3 Barstool Seat Cushion Replacement: Schritt 5, Bild 2 von 3 Barstool Seat Cushion Replacement: Schritt 5, Bild 3 von 3
      • Take a marker and trace around the board onto the foam.
      • Draw another circle about two inches around the first one to ensure there is extra room for cutting.
      • Cut the second circle using a box cutter.
      Frag FixBot
    6. Barstool Seat Cushion Replacement: Schritt 6, Bild 1 von 3 Barstool Seat Cushion Replacement: Schritt 6, Bild 2 von 3 Barstool Seat Cushion Replacement: Schritt 6, Bild 3 von 3
      • Place the board back on to ensure it fits right.
      • Remove the board and cut the first circle you made with the box cutter.
      • To create the domed shape for the seat, flip the foam over and shave cut into and around the foam.
      Frag FixBot
    7. Barstool Seat Cushion Replacement: Schritt 7, Bild 1 von 3 Barstool Seat Cushion Replacement: Schritt 7, Bild 2 von 3 Barstool Seat Cushion Replacement: Schritt 7, Bild 3 von 3
      • Place the fabric flat on your workspace, then center the foam and board on top of it with the domed side facing down against the fabric.
      • Trace a circle onto the fabric by running a marker directly against the edge of the board.
      • Draw a second, larger circle about five inches outside the first line.
      • You want there to be extra fabric. This will help with assembling the pieces.
      Frag FixBot
    8. Barstool Seat Cushion Replacement: Schritt 8, Bild 1 von 3 Barstool Seat Cushion Replacement: Schritt 8, Bild 2 von 3 Barstool Seat Cushion Replacement: Schritt 8, Bild 3 von 3
      • Cut out the second circle.
      • Place the pieces in the center of the first circle.
      • Place sewing pins in the four tiny holes.
      • These are the screw holes. You don't want to staple over them.
      Frag FixBot
    9. Barstool Seat Cushion Replacement: Schritt 9, Bild 1 von 3 Barstool Seat Cushion Replacement: Schritt 9, Bild 2 von 3 Barstool Seat Cushion Replacement: Schritt 9, Bild 3 von 3
      • Apply downward pressure to the board, pull a section of the fabric tight toward yourself, and secure it to the edge of the board with a staple.
      • Rotate the board and repeat this process along the entire perimeter until the fabric is completely secured.
      • Make sure you don't staple over the sewing pins.
      • Trim away any excess fabric remaining outside the staple line.
      Frag FixBot
    10. Barstool Seat Cushion Replacement: Schritt 10, Bild 1 von 3 Barstool Seat Cushion Replacement: Schritt 10, Bild 2 von 3 Barstool Seat Cushion Replacement: Schritt 10, Bild 3 von 3
      • Place the bottom fabric back on the bottom.
      • Line it up with the sewing pins, and place the pins back in the holes.
      • Staple the fabric in place all along the edge of the board.
      Frag FixBot
    11. Barstool Seat Cushion Replacement: Schritt 11, Bild 1 von 3 Barstool Seat Cushion Replacement: Schritt 11, Bild 2 von 3 Barstool Seat Cushion Replacement: Schritt 11, Bild 3 von 3
      • Align the metal frame with the sewing pins and place it flat against the board.
      • Remove the sewing pins one at a time, replacing each one with a Phillips screw to secure the plate in place.
      • Place the stool frame or legs onto the bottom of the seat, aligning them with the four pre-drilled holes.
      • Use the Allen wrench to tighten the hex screws and secure the legs to the base.
      Frag FixBot
    12. Barstool Seat Cushion Replacement: Schritt 12, Bild 1 von 3 Barstool Seat Cushion Replacement: Schritt 12, Bild 2 von 3 Barstool Seat Cushion Replacement: Schritt 12, Bild 3 von 3
      • Flip the barstool over, slide the backrest back in place, and screw them back in place.
      • The barstool is now complete.
      Frag FixBot
Ziellinie
Hannah Dabney
205 Reputation
1 Anleitung geschrieben
Rose State College, Team 2-3, Kirkman Spring 2026 Mitglied von Rose State College, Team 2-3, Kirkman Spring 2026
ROSE-KIRKMAN-S26S2G3
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 44
Insgesamt: 113
