Einleitung
The battery can go bad on many devices. This guide includes removing the back plate and then detaching the battery from the rest of the watch.
Was du brauchst
Push in plastic opening tool until the components click and pop out of the holder.
Repeat steps for other band.
Remove four 4mm screws using a PH000 screwdriver.
Remove back plate.
Use the flat end of the spudger to carefully lift the battery until adhesive seal is broken.
Use the pointy edge of the spudger tool to detach battery leads from the circuit board.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
