Einleitung
This guide shows how to replace the LED screen. This is a more complicated guide because it involves removing the back plate of the watch along with the battery.
Was du brauchst
Push in plastic opening tool until the components click and pop out of the holder.
Repeat steps for other band.
Remove four 4mm screws using a PH000 screwdriver.
Remove back plate.
Use the flat end of the spudger to carefully lift the battery until adhesive seal is broken.
Use the pointy edge of the spudger tool to detach battery leads from the circuit board.
Use PH000 screw driver to remove two 6mm bracketed screws.
Remove bracket.
Use spudger tool to lift the clasp of LED connector strip and remove from watch case.
