Zum Hauptinhalt wechseln
Einleitung
The bands of the Basis Peak allow for several size adjustments for a snug fit to the user's wrist. A properly adjusted band is crucial to the functioning of the sensor on the underside of the watch. If the band is damaged or visibly tarnished, users can easily replace it with this guide. Two spring latches on the underside of the band halves must be released and the band halves will come right off.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Basis Peak Band Replacement, Band: Schritt 1, Bild 1 von 1
    • Flip the watch over to view the back panel and sensor. Arrange the watch so that the band clasp is away from you.
    • Keep the watch in this position to help you follow the rest of the guide.
  2. Basis Peak Band Replacement: Schritt 2, Bild 1 von 1
    • Release the spring latches on the underside of each band to remove the bands from the frame.
Abschluss
To reattach the bands, follow these instructions in reverse order.
UMass Dartmouth, Team S4-G4, Julie Spring 2017 Mitglied von UMass Dartmouth, Team S4-G4, Julie Spring 2017
UMASSD-JULIE-S17S4G4
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 124
