Einleitung
This guide gives you the information you need to replace the battery on the Basis Peak product. Each step is shown with pictures to make sure you won't get lost through your work. Its quite simple to get through especially with the helpful guidance provided. There's no tricks and the product can only be dissemble through this one way.
Was du brauchst
Flip the watch over and orient it such that the buckle is away from you and the back panel is revealed.
Remove the four base screws using a size 2 TORX screwdriver to separate the back plate from the frame.
Disconnect the ribbon cable on the left side of the motherboard by using a spudger.
Use a spudger and apply pressure to the white plastic wall to the right of the motherboard. Use this to lever the electronics out of the frame.
Remove the right side ribbon cable by pulling it off with your fingers.
Use the spudger tool to poke out the exposed motherboard section as seen in the photo.
Put a nylon spudger underneath the battery's press-fit connector and lift up to free the ribbon cable and motherboard.
