Zum Hauptinhalt wechseln
MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement
Was du brauchst
  1. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement, Faucet: Schritt 1, Bild 1 von 1
    • Turn the water shutoff valve underneath the sink downwards to stop the flow of water.
  2. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 2, Bild 1 von 1
    • Turn the tap(s) on to release any pressure build-up in the pipes.
  3. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 3, Bild 1 von 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 3, Bild 2 von 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 3, Bild 3 von 3
    • With pliers, unscrew the mounting nuts underneath the sink by turning them counterclockwise.
  4. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 4, Bild 1 von 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 4, Bild 2 von 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 4, Bild 3 von 3
    • With an adjustable wrench, unscrew the bolts connecting the faucet pipes to the supply lines.
    • After unscrewing the bolts, the faucet pipes should easily come off.
  5. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 5, Bild 1 von 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 5, Bild 2 von 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 5, Bild 3 von 3
    • Disconnect the lift rod for the drain plug by pushing it off the metal rod.
  6. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 6, Bild 1 von 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 6, Bild 2 von 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 6, Bild 3 von 3
    • After everything is completely disconnected, pull the faucet out from the top.
  7. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 7, Bild 1 von 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 7, Bild 2 von 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 7, Bild 3 von 3
    • Clean the area in which the replacement faucet will be placed to ensure that there is a flat surface.
  8. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 8, Bild 1 von 2 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 8, Bild 2 von 2
    • Insert the pipes of the replacement faucet through the sink holes.
    • Each pipe will correspond to each hole on the right and left.
  9. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 9, Bild 1 von 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 9, Bild 2 von 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 9, Bild 3 von 3
    • With pliers, tighten the mounting nuts underneath the sink in the same location they were removed from.
  10. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 10, Bild 1 von 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 10, Bild 2 von 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 10, Bild 3 von 3
    • Reattach the faucet pipes to the supply lines and tighten the bolts with an adjustable wrench.
    • Tighten the left and the right pipe.
  11. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 11, Bild 1 von 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 11, Bild 2 von 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 11, Bild 3 von 3
    • Reattach the lift rod for the drain plug by lining up the holes and pushing it through the metal rod.
  12. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 12, Bild 1 von 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 12, Bild 2 von 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 12, Bild 3 von 3
    • Turn the shutoff valve upwards to line it up with the pipe and resume the flow of water.
  13. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: Schritt 13, Bild 1 von 1
    • Turn on the tap and inspect for leakage. If any leakage does appear, refer to step 1 & 10 and make the pipe bolts tighter.
    • Otherwise, the replacement sink is completely installed.
Abschluss
To remove the replacement faucet, follow steps 1-6.
Manahal Khalil
217 Reputation
1 Anleitung geschrieben
York University, Team E-9, Melo-Thaiss Fall 2021 Mitglied von York University, Team E-9, Melo-Thaiss Fall 2021
YORK-MELO-THAISS-F21SEG9
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 47
Insgesamt: 806
