Einleitung
This guide will provide step by step instructions on how to locate and open the battery compartment, then install the batteries.
Werkzeuge
Kein Werkzeug erforderlich.
Ersatzteile
  1. Locate the battery compartment on the bottom right of the camera.
    • Locate the battery compartment on the bottom right of the camera.
  2. While holding the camera with the lens facing toward you, slide the lock button to the right and pull the battery door towards you. The battery door should pop open. If the door does not pop open, gently lift the door using your finger.
    • While holding the camera with the lens facing toward you, slide the lock button to the right and pull the battery door towards you. The battery door should pop open.
    • If the door does not pop open, gently lift the door using your finger.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Remove the dead batteries.  The easiest way to do this is by turning the camera right side up and gently tapping the lens side of the camera against your hand until they fall out.  If this does not work, you can simply pull them out.
    • Remove the dead batteries. The easiest way to do this is by turning the camera right side up and gently tapping the lens side of the camera against your hand until they fall out. If this does not work, you can simply pull them out.
  5. Insert fresh AA batteries into the compartment as demonstrated in the picture to the left. The orientation of the batteries is important to ensure the camera works properly.
    • Insert fresh AA batteries into the compartment as demonstrated in the picture to the left. The orientation of the batteries is important to ensure the camera works properly.
    • Close the battery door.
      • Remember to slide the switch back into the lock position.
Abschluss
Reassembly of the camera is the final step in the guide.
Richard
3 Reputation
1 Anleitung geschrieben
Cal Poly, Team 9-43, Regan Spring 2012 Mitglied von Cal Poly, Team 9-43, Regan Spring 2012
CPSU-REGAN-S12S9G43
5 Mitglieder
6 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 1,655
