Einleitung
Prereq for disconnecting the battery of your Samsung Galaxy A10e.
Was du brauchst
Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole in the SIM card tray.
Press to eject the tray.
Insert an opening pick between the screen and the back cover on the bottom of the phone where the charging port is located.
Slide the opening pick along the left edge to the top left corner of the phone, to release the clips.
Slide the opening pick from the top left corner to the top right corner to release the plastic clips.
Slide the opening pick from the top right corner to the bottom right corner to release the remaining clips.
Remove screws from the motherboard antenna cover.
3 Phillips #00, 3mm length.
Use a spudger to disconnect the battery by prying the connector straight up from its socket.
5 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Do I need to heat up the screen of my phone to make it easier for me to get the back cover off of my phone?
no, it just clips on, there's no adhesive
