Zum Hauptinhalt wechseln
Black and Decker SS12C Battery Replacement
Was du brauchst
  1. Black and Decker SS12C Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Black and Decker SS12C Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Black and Decker SS12C Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Detach the battery unit from the drill by pressing down on the battery release button and pulling the battery towards you.
  2. Black and Decker SS12C Battery Replacement: Schritt 2, Bild 1 von 1
    • Now that the battery component is detached, remove the 4 screws indicated [16mm].
    • Remove each screw with the T10 Torx Security Bit Screwdriver by turning counterclockwise.
  3. Black and Decker SS12C Battery Replacement: Schritt 3, Bild 1 von 3 Black and Decker SS12C Battery Replacement: Schritt 3, Bild 2 von 3 Black and Decker SS12C Battery Replacement: Schritt 3, Bild 3 von 3
    • Now that the screws are detached, separate the two sides of the battery.
  4. Black and Decker SS12C Battery Replacement: Schritt 4, Bild 1 von 2 Black and Decker SS12C Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove the highlighted, orange component and set aside.
  5. Black and Decker SS12C Battery Replacement: Schritt 5, Bild 1 von 3 Black and Decker SS12C Battery Replacement: Schritt 5, Bild 2 von 3 Black and Decker SS12C Battery Replacement: Schritt 5, Bild 3 von 3
    • Grip the battery pack and detach it from the casing by pulling it upward.
    • Spring may fall out during the process.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
I have a CD 9600 Type 3 with a B&D PS120 pack. are there any replacement packs available? Thanks!
Scott D. Deutsch - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 13
Insgesamt: 830
