Zum Hauptinhalt wechseln
Nextbook Premium 7SE Battery Replacement
Was du brauchst
  1. Nextbook Premium 7SE Battery Replacement, Back Cover: Schritt 1, Bild 1 von 3 Nextbook Premium 7SE Battery Replacement, Back Cover: Schritt 1, Bild 2 von 3 Nextbook Premium 7SE Battery Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
    • Slide the opening tool to the right and slowly continue to separate the back cover from the device.
    • Avoid prying on the buttons, as they are easily damaged.
  2. Nextbook Premium 7SE Battery Replacement: Schritt 2, Bild 1 von 1
    • Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
  3. Nextbook Premium 7SE Battery Replacement, Battery: Schritt 3, Bild 1 von 1
    • Remove masking tape from the battery.
  4. Nextbook Premium 7SE Battery Replacement: Schritt 4, Bild 1 von 3 Nextbook Premium 7SE Battery Replacement: Schritt 4, Bild 2 von 3 Nextbook Premium 7SE Battery Replacement: Schritt 4, Bild 3 von 3
    • Pry the battery from the base using the nylon spudger and move it away from the motherboard.
    • Handle the battery with care to avoid damaging it.
  5. Nextbook Premium 7SE Battery Replacement: Schritt 5, Bild 1 von 3 Nextbook Premium 7SE Battery Replacement: Schritt 5, Bild 2 von 3 Nextbook Premium 7SE Battery Replacement: Schritt 5, Bild 3 von 3
Abschluss
To reassemble your device, follow these instructions in reverse order, being careful when re-soldering the contacts back into place.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Baylor, Team 4-1, Williams Fall 2016 Mitglied von Baylor, Team 4-1, Williams Fall 2016
BU-WILLIAMS-F16S4G1
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 698
