Zum Hauptinhalt wechseln
Battery disassembly
Was du brauchst
  1. Battery disassembly, Remove the battery: Schritt 1, Bild 1 von 3 Battery disassembly, Remove the battery: Schritt 1, Bild 2 von 3 Battery disassembly, Remove the battery: Schritt 1, Bild 3 von 3
    • Turn the laptop upside down and gently lay it down on a flat surface.
    • Slide the battery release latch to the right and the battery will pop up slightly.
    • While keeping the latch slid with one hand, grab the battery with the other hand and remove it by pivoting it upward.
    • At this point some users would turn the laptop upside down once again and press the power button a couple of times. They say that this should help dissipating all of the remaining electricity around the device. Up to you :)
Abschluss
Ein Kommentar
Maybe rename this guide "laptop battery removal" seeing as no dissasembling is taking place.
sephiroth_dk - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 336
