Einleitung
This guide will walk you through the process of replacing the ambient air intake filters in a Bear 1000 Ventilator. Found on page 97 in the full service manual.
Was du brauchst
Turn off the ventilator and disconnect from AC power and pressurized gas at the wall sources.
Vacuum all surfaces inside the ventilator. Be sure to reach areas around connectors, circuit boards and pneumatic assembies.
Fast fertig!
Abschluss
