Einleitung
This guide will walk you through the process of replacing the Power entry Module in a Bear 1000 Ventilator. Found on page 88 in the full service manual.
Was du brauchst
Remove the ribbon cable at the connection on the oxygen blender control board.
Mark the plastic hoses attached to the oxygen blender (so you can put them back on the same way) and then remove.
The air/oxygen blender has two screws close to the control board. Remove them and remove the unit.
Remove the pneumatic and electrical connections labeled.
Mark or label the 6 faston connections as to position and remove
Mark or label the two wires going to the power switch and remove at the power switch end
Using an allen wrench, remove the mounting screwa and nuts from the Power Entry Module.
After removing the heat shrink tubing, unsolder the two lower wires from the Power Entry Module, noting locations.
Solder the wires to the replacement module, covering the joints with heat shrink tubing.
Transfer the voltage selector drum from the original module to the replacement and reinstall.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
