Einleitung
Involves opening the case, removing ribbon cable from motherboard, removing four screws, prying off the 'b' button from the hardware and replace with new 'b' button.
Was du brauchst
Using a plastic opening tool, pry the casing from the rest of the device.
Pry all the way around the edge and then pull apart.
Using your thumb, remove the 8 rubber plugs in order to get to the screws.
Simply rub them towards the speakers and they will slide out enough to grip the edge and pull them out.
Using a Phillips #2 screwdriver, remove the 8 (10mm maxi-loc Phillips #2) screws that hold the casing together.
Pull apart the front casing from the back casing, slowly. Try to avoid any tension on any of the connected cables.
Gently pull on the plastic tab at the base of the ribbon cable to remove it from the motherboard.
Using your thumb and index finger, pull upwards on the base of the the power cable to remove it from the motherboard.
Remove the speaker cables by using gentle constant force with fingers.
Separate the front case with the speakers and 'b' button from the mother board housing.
Using a Phillips #2 screwdriver, remove the 4 (8mm pan head Phillips #2) screws using a Philips #02 screwdriver.
Using a plastic opening tool pry the 'b' button housing from the casing.
Use fingers to completely remove the 'b' button housing from the casing.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
