Zum Hauptinhalt wechseln
Beats Solo 2 Wireless Battery Replacement
Was du brauchst
  1. Beats Solo 2 Wireless Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Beats Solo 2 Wireless Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Beats Solo 2 Wireless Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Insert an opening pick in the seam between the right outer speaker casing and the speaker housing.
    • Slide the pick around the perimeter of the casing until the casing releases entirely from the speaker housing.
    • Failure to loosen the seams may result in the piece breaking partially or completely during removal.
  2. Beats Solo 2 Wireless Battery Replacement: Schritt 2, Bild 1 von 3 Beats Solo 2 Wireless Battery Replacement: Schritt 2, Bild 2 von 3 Beats Solo 2 Wireless Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove the right outer speaker casing.
  3. Beats Solo 2 Wireless Battery Replacement: Schritt 3, Bild 1 von 3 Beats Solo 2 Wireless Battery Replacement: Schritt 3, Bild 2 von 3 Beats Solo 2 Wireless Battery Replacement: Schritt 3, Bild 3 von 3
    • Use tweezers to disconnect the battery connector from the circuit board.
    • Do not pull on the wires.
  4. Beats Solo 2 Wireless Battery Replacement: Schritt 4, Bild 1 von 3 Beats Solo 2 Wireless Battery Replacement: Schritt 4, Bild 2 von 3 Beats Solo 2 Wireless Battery Replacement: Schritt 4, Bild 3 von 3
    • Use an opening pick to gently pry up the battery.
    • The battery is secured in the housing with adhesive. You can apply some high-concentration alcohol beneath the battery to help loosen the adhesive.
    • Avoid bending or puncturing the battery.
  5. Beats Solo 2 Wireless Battery Replacement: Schritt 5, Bild 1 von 1
    • Lift the battery up and out of the chassis.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cooper Truong
277 Reputation
2 Anleitungen geschrieben
IUPUI, Team 2-1, Harley Spring 2024 Mitglied von IUPUI, Team 2-1, Harley Spring 2024
IUPUI-HARLEY-S24S2G1
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 13
Insgesamt: 84
