Zum Hauptinhalt wechseln
Beats Solo 2 Wireless Earpads Replacement
Was du brauchst
  1. Beats Solo 2 Wireless Earpads Replacement, Earpads: Schritt 1, Bild 1 von 3 Beats Solo 2 Wireless Earpads Replacement, Earpads: Schritt 1, Bild 2 von 3 Beats Solo 2 Wireless Earpads Replacement, Earpads: Schritt 1, Bild 3 von 3
    • Set the headphones down on a flat surface.
    • Insert a plastic card or opening pick between between the earpads and the speaker housing.
    • Carefully pry around the entire perimeter of the the pads until they fully release.
    Frag FixBot
    Kommentar hinzufügen
  2. Beats Solo 2 Wireless Earpads Replacement: Schritt 2, Bild 1 von 1
    • Use the card to clean up the adhesive residue left on the headphones.
    • Apply high-concentration isopropyl alcohol to a cloth and use it to remove any lingering adhesive.
    Frag FixBot
  3. Beats Solo 2 Wireless Earpads Replacement: Schritt 3, Bild 1 von 1
    • Fold the other side of the headphones you are not working on.
    • This makes it easier to work and focus on the side you are on.
    • Carefully pick up the new pads and line them up with the Beats.
    • The new earpads come with the adhesive on them already; you just have to peel the plastic covering off.
    Frag FixBot
  4. Beats Solo 2 Wireless Earpads Replacement: Schritt 4, Bild 1 von 1
    • Press down on the new pad to make sure it adheres to the headphones.
    • Make sure to go around the pad and press down on every part.
    Frag FixBot
  5. Beats Solo 2 Wireless Earpads Replacement: Schritt 5, Bild 1 von 1
    • Find a large object and place the headphones on it just like the object is wearing the headphones.
    • Leave the headphones on the object for an hour so it can clamp the earpads to itself.
    • After 1 hour, you are good to go.
    Frag FixBot
Ziellinie
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 12
Letzte 30 Tage: 73
Insgesamt: 1,338
