Zum Hauptinhalt wechseln
Beats Solo 2 Wireless Power Button Replacement
Was du brauchst
  1. Beats Solo 2 Wireless Power Button Replacement, Power Button: Schritt 1, Bild 1 von 3 Beats Solo 2 Wireless Power Button Replacement, Power Button: Schritt 1, Bild 2 von 3 Beats Solo 2 Wireless Power Button Replacement, Power Button: Schritt 1, Bild 3 von 3
    • Insert an opening pick in the seam between the right outer speaker casing and the speaker housing.
    • Slide the pick around the perimeter of the casing until the casing releases entirely from the speaker housing.
    • If you encounter any resistance, continue to pry along any spots where the seam is still close together.
    • Failure to loosen the seams may result in the piece breaking partially or completely during removal.
  2. Beats Solo 2 Wireless Power Button Replacement: Schritt 2, Bild 1 von 2 Beats Solo 2 Wireless Power Button Replacement: Schritt 2, Bild 2 von 2
    • Remove the right outer casing.
  3. Beats Solo 2 Wireless Power Button Replacement: Schritt 3, Bild 1 von 3 Beats Solo 2 Wireless Power Button Replacement: Schritt 3, Bild 2 von 3 Beats Solo 2 Wireless Power Button Replacement: Schritt 3, Bild 3 von 3
    • Use a Phillips screwdriver to remove the 2.8 mm screw on the outer shell of the headphones.
  4. Beats Solo 2 Wireless Power Button Replacement: Schritt 4, Bild 1 von 1
    • Remove the power button with your hand or a spudger by prying out the end that is still attached.
    • Beware of the sponge piece when putting the power button assembly back together.
Abschluss
Victor Diuno
130 Reputation
1 Anleitung geschrieben
IUPUI, Team 2-1, Harley Spring 2024 Mitglied von IUPUI, Team 2-1, Harley Spring 2024
IUPUI-HARLEY-S24S2G1
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 13
Insgesamt: 94
