Zum Hauptinhalt wechseln
Beats Solo HD Speaker Replacement
Was du brauchst
  1. Beats Solo HD Speaker Replacement, Remove the foam pads from both the left and right speakers.: Schritt 1, Bild 1 von 2 Beats Solo HD Speaker Replacement, Remove the foam pads from both the left and right speakers.: Schritt 1, Bild 2 von 2
    • Remove the foam pads by twisting them counterclockwise.
    • The pads should release from the grooves that are housed on the speaker inside.
  2. Beats Solo HD Speaker Replacement, Unscrew the speakers from the housing: Schritt 2, Bild 1 von 2 Beats Solo HD Speaker Replacement, Unscrew the speakers from the housing: Schritt 2, Bild 2 von 2
    • There should be approximately three screws holding the right speaker. Unscrew them to gain access to the wiring of the speakers.
    • Keep the screws in a safe place. They are small and can easily be lost.
  3. Beats Solo HD Speaker Replacement, Desolder the connections to the speaker: Schritt 3, Bild 1 von 2 Beats Solo HD Speaker Replacement, Desolder the connections to the speaker: Schritt 3, Bild 2 von 2
    • Using safety gloves, desolder the two wires of the speaker.
    • Leave the desoldered and unstripped wires for the next step.
  4. Beats Solo HD Speaker Replacement, Repeat steps in reverse to re-assemble: Schritt 4, Bild 1 von 1
    • Follow the instructions in reverse to put together the speaker in the housing, as well as the foam pad over the speaker.
    • Solder the new speaker to the two wires of the headphones.
    • Make sure to pack in all of the companents back into the housing when finished with this step.
  5. Beats Solo HD Speaker Replacement, Repeat steps for left speaker: Schritt 5, Bild 1 von 1
    • If you need to repair the left speaker, there may be an additional step you need to take to replace the speakers. This takes the audio jack into account.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
redacted
544 Reputation
1 Anleitung geschrieben
USF Tampa, Team 1-1, Donnelly Fall 2014 Mitglied von USF Tampa, Team 1-1, Donnelly Fall 2014
USFT-DONNELLY-F14S1G1
1 Mitglied
2 Anleitungen geschrieben
3 Kommentare
Hello. I also have 1 damaged Monster Beats Solo. It was bought in 2013. The right speaker does not working properly - it sounds softer (opposite of lourder) than the left speaker and whenever I move, I can feel the sound of something loose inside the right ear cup/speaker. I already found some sellers selling the replacement speakers on ebay. Before buying the replacement parts, I decided to open the ear cup myself to check whether it is easy to open or not. However, so far I am unable to open it. I avoind using too much force because it is afraid that I might break the headphone.
SHAMSUL FAISAL MOHD HUSSEIN - Antwort
According to some websites, the twist counter clockwise removal of the headphone pad is indicative of a fake beats solo HD, the genuine ones have fixed pads apparently. I can't guarantee this, but I do have a set of solo HDs with a faulty speaker and I can't easily remove the pad either
Simon16a - Antwort
you forgot to mention polarity which matters if you mess that up ull get a lack of bass and phasing issues positive and negative should be clearly marked and a link to a proper replacement you should give proper instructions on how to check for proper polarity with a volt meter for those who dont know.
bob king - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 37
Letzte 30 Tage: 154
Insgesamt: 105,735
