Zum Hauptinhalt wechseln
Beats Studio 2.0 Wireless Left Interior Side Panel Replacement
Was du brauchst
  1. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement, Left Interior Side Panel: Schritt 1, Bild 1 von 1
    • Use metal spudger to pry away ear cushion.
  2. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: Schritt 2, Bild 1 von 1
    • Remove ear cushion from headphones (attached by adhesive).
  3. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: Schritt 3, Bild 1 von 1
    • Remove two screws from the metal hinge using a Phillips head screwdriver to allow more motion from the speaker housing and more accessibility.
  4. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: Schritt 4, Bild 1 von 1
    • Remove five screws using a Phillips head screwdriver from speaker housing.
  5. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: Schritt 5, Bild 1 von 1
    • Pull speaker away to access second secondary housing.
    • Be careful not to stress wires and break solder points.
  6. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: Schritt 6, Bild 1 von 2 Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: Schritt 6, Bild 2 von 2
    • Raise center cover.
    • Remove screw from center of housing.
  7. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: Schritt 7, Bild 1 von 1
    • Pull secondary housing away gently being careful not to damage the wires.
  8. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: Schritt 8, Bild 1 von 1
    • Remove four screws using a Phillips head screwdriver to remove the third housing.
  9. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: Schritt 9, Bild 1 von 3 Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: Schritt 9, Bild 2 von 3 Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: Schritt 9, Bild 3 von 3
    • Disconnect wires gently.
    • Be gentle with the wires ensuring to pull them through with care to eliminate possible shortages.
  10. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: Schritt 10, Bild 1 von 3 Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: Schritt 10, Bild 2 von 3 Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: Schritt 10, Bild 3 von 3
    • Pass wire through new housing and reconnect wires.
  11. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: Schritt 11, Bild 1 von 1
    • Snap housing into place.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Antares Cam
235 Reputation
1 Anleitung geschrieben
colby and cameron Mitglied von colby and cameron
Community
2 Mitglieder
2 Kommentare
Thank you for your tutorial!
Jonathan Concepcion - Antwort
appreciate it, fixed both side panels on my beats
mridha31 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 33
Insgesamt: 5,623
