Einleitung
Removing the ear cushion is an important first step to accessing the speaker housing. Unless you are only replacing the headband, You MUST remove the ear cushions to access the other components.
Was du brauchst
Pinch the ear cushion between your thumb and forefinger.
Carefully pull the cushion directly away from the earpiece.
Repeat for the other ear cushion.
Use the plastic opening tool to remove the black ring from the speaker. This will allow you to access the screws on the metal ring.
Congratulations, you now have access to the rest of the speaker!
The black lip is located on the back side of the ear cushion.
15 weitere Personen haben diese Anleitung absolviert.
4 Kommentare
De nada me sirve saber cómo colocarlos si no sé donde conseguirlos... Ese debería ser el paso 1 del instructivo...
Hi - do you know where i can buy the replacement ear cushions for these particular headphones?
Yes! We do offer these here:
Cooper -
