Einleitung
This guide will help to replace a broken or faulty charging port in the Beboncool Gamepad for Nintendo Switch. If your device does not seem to receive any power despite being plugged in to a known working outlet with a known working cable, the charging port may need to be replaced.
Was du brauchst
Use the plastic opening tool to remove the blue plastic grips from the sides of the controller.
Use the Phillips #0 screwdriver to remove the seven 5mm screws from the back of the controller.
Gently separate the two halves of the controller.
Be sure to slide the small circuit boards out of the covers to be able to separate the two halves
Use the Phillips #0 screwdriver to remove the two 3.5mm screws holding the circuit board in place.
Lift the motherboard from the back case with the vibration motors and button boards attached.
Gently pull the battery from the circuit board, leaving it connected to the board with its lead wires.
Remove the charging port from the edge of the motherboard by desoldering each of its four solder points and lifting the port from the board.
