Zum Hauptinhalt wechseln
Bed Head Wave Artist Deep Waver Power Lead Connector Replacement
Was du brauchst
  1. Bed Head Wave Artist Deep Waver Power Lead Connector Replacement, Lower Handle Housing: Schritt 1, Bild 1 von 2 Bed Head Wave Artist Deep Waver Power Lead Connector Replacement, Lower Handle Housing: Schritt 1, Bild 2 von 2
    • Before disassembling your Deep Waver, be sure to unplug the device to avoid electric shock, and make sure the heating elements of the device are cool to avoid burns.
    • Unlock the handle of your Deep Waver to gain access to the screws you need to remove.
    • Remove two 10 mm Phillips #01 screws from the lower handle housing.
    • Remove one 10 mm Phillips #02 screw from the lower handle housing.
  2. Bed Head Wave Artist Deep Waver Power Lead Connector Replacement: Schritt 2, Bild 1 von 1
    • Pry the black screw cover off the side of the lower handle housing using a fine-point spudger or pick. This side will have the model number and other product information embossed on it.
  3. Bed Head Wave Artist Deep Waver Power Lead Connector Replacement: Schritt 3, Bild 1 von 1
    • Remove one 10 mm Phillips 1 screw from the handle joint.
  4. Bed Head Wave Artist Deep Waver Power Lead Connector Replacement: Schritt 4, Bild 1 von 1
    • Pry the black screw cover off the other side of the lower handle housing. This side will have the power switch located on it.
  5. Bed Head Wave Artist Deep Waver Power Lead Connector Replacement: Schritt 5, Bild 1 von 1
    • Cut along the length of the black housing retainer with a rotary tool to split and remove the retainer.
  6. Bed Head Wave Artist Deep Waver Power Lead Connector Replacement: Schritt 6, Bild 1 von 1
    • Split the lower handle housing apart using a plastic opening tool.
    • Begin splitting the housing at one end rather than the center to avoid cracking the casing.
  7. Bed Head Wave Artist Deep Waver Power Lead Connector Replacement, Power Lead Connector: Schritt 7, Bild 1 von 2 Bed Head Wave Artist Deep Waver Power Lead Connector Replacement, Power Lead Connector: Schritt 7, Bild 2 von 2
    • Apply heat to both terminals of the power leads with a soldering iron. This will melt the solder so each power lead can be removed.
    • Gently pull on each power lead to remove them from the circuit board.
Abschluss
To reassemble your device, follow these instructions in reverse order. Once each half of the housing have been put back together, install a new Housing Retainer to replace the one you cut off.
Grant Peters
401 Reputation
4 Anleitungen geschrieben
IUPUI, Team S6-G3, Baechle Fall 2017 Mitglied von IUPUI, Team S6-G3, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G3
3 Mitglieder
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 19
Letzte 30 Tage: 21
Insgesamt: 498
