Zum Hauptinhalt wechseln
Beiens Cartoon RC Race Car Car Battery Replacement
Was du brauchst
  1. Beiens Cartoon RC Race Car Car Battery Replacement, Car Battery: Schritt 1, Bild 1 von 1
    • On the bottom of the car, unscrew the 6.2 mm screw that houses the batteries using a Philips 00 precision screwdriver.
  2. Beiens Cartoon RC Race Car Car Battery Replacement: Schritt 2, Bild 1 von 1
    • Pull up the tab to reveal the battery compartment.
  3. Beiens Cartoon RC Race Car Car Battery Replacement: Schritt 3, Bild 1 von 1
    • Insert AA batteries into the 3 spaces with the flat end of the battery facing the metal spring.
    • Be sure to insert the batteries with the positive and negative ends facing the right direction. The flat negative end of the battery should be in contact with the spring in the remote control car.
Abschluss
This guide was made to work for the Beiens Cartoon RC Race Car with AA batteries, but it should also work with other similar modeled RC cars that take AA batteries.
Amber Ashley
329 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 1-6, Leahy Fall 2015 Mitglied von USF Tampa, Team 1-6, Leahy Fall 2015
USFT-LEAHY-F15S1G6
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 584
