Einleitung
This guide will walk you through how to replace the lens piece on the NetCam.
Was du brauchst
Use a wrench to loosen up the stand from the back in order to hold the NetCam more comfortably.
Work a plastic opening tool into the seam and pry the face plate away from the back panel.
Carefully use your fingers to gently pull out the white attachment from the tan colored part.
Use a Phillips #0 screwdriver to take out the two 1.2 mm screws on the board.
The speaker wires are attached with the board. It can be unattached gently by pulling out the white attachment from the port.
Flip the circuit board to the back side.
Fold down the tape with your finger.
With the Phillips #0 screwdriver, unscrew the two 1.2 mm screws.
Flip the circuit board back to the other side.
Unscrew the screw with a Phillips #0 screw driver.
Use the tweezers to pull the white attachment out from the port a little.
Then, take your fingers and gently pull the white attachment out from the tan port.
