Zum Hauptinhalt wechseln
Belkin NetCam HD Microphone Replacement
Was du brauchst
  1. Belkin NetCam HD Microphone Replacement, Case: Schritt 1, Bild 1 von 1
    • Use a wrench to loosen up the stand from the back in order to hold the NetCam more comfortably.
  2. Belkin NetCam HD Microphone Replacement: Schritt 2, Bild 1 von 1
    • Work a plastic opening tool into the seam and pry the face plate away from the back panel.
  3. Belkin NetCam HD Microphone Replacement: Schritt 3, Bild 1 von 2 Belkin NetCam HD Microphone Replacement: Schritt 3, Bild 2 von 2
    • Use pressure to separate the covers.
    • When pulling the device apart, separate from the bottom up in order to avoid pulling the wiring at the top apart.
  4. Belkin NetCam HD Microphone Replacement, Microphone: Schritt 4, Bild 1 von 2 Belkin NetCam HD Microphone Replacement, Microphone: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use tweezers to gently pull out the white attachment from the port.
    • Use your fingers to pull out the white attachment from the tan port on the front of the board a little.
  5. Belkin NetCam HD Microphone Replacement: Schritt 5, Bild 1 von 2 Belkin NetCam HD Microphone Replacement: Schritt 5, Bild 2 von 2
    • Use a pair of tweezers to wedge between the mic and the rubber guard to remove the mic from the front cover.
    • If the rubber guard comes off with the mic just remove the guard from mic and place back on the front cover.
Abschluss
USF Tampa, Team 3-5, Sullivan Fall 2016 Mitglied von USF Tampa, Team 3-5, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G5
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 340
