Einleitung
This guide will walk you through how to replace the front casing on the NetCam.
Was du brauchst
Use a wrench to loosen up the stand from the back in order to hold the NetCam more comfortably.
Work a plastic opening tool into the seam and pry the face plate away from the back panel.
Use tweezers to gently pull out the white attachment from the port.
Use your fingers to pull out the white attachment from the tan port on the front of the board a little.
Use a pair of tweezers to wedge between the mic and the rubber guard to remove the mic from the front cover.
Carefully use your fingers to gently pull out the white attachment from the tan colored part.
