Einleitung
This guide walks you through how to replace the switch cover on the NetCam.
Was du brauchst
Use a wrench to loosen up the stand from the back in order to hold the NetCam more comfortably.
Work a plastic opening tool into the seam and pry the face plate away from the back panel.
Carefully use your fingers to gently pull out the white attachment from the tan colored part.
Use a Phillips #0 screwdriver to take out the two 1.2 mm screws on the board.
The speaker wires are attached with the board. It can be unattached gently by pulling out the white attachment from the port.
On the back of the board pull the switch slowly upward to take it off.
Eine weitere Person hat diese Anleitung absolviert.
