Zum Hauptinhalt wechseln
Einleitung
What you will be doing is changing your battery.
  1. The battery is located on the back of the camera.
    • The battery is located on the back of the camera.
  2. On the bottom of the camera the is a button that holds the battery. Press down on that button and pull the battery towards you.
    • On the bottom of the camera the is a button that holds the battery.
    • Press down on that button and pull the battery towards you.
Abschluss
Jerry Hadjah
525 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 8-4, Botvin Spring 2016 Mitglied von UMass Dartmouth, Team 8-4, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G4
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 319
