Zum Hauptinhalt wechseln
Einleitung
In this guide you will be taking apart the Bell and Howell DNV16HDZ camera to replace the lens. There are different lens types that you can replace it with.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the five 30mm Phillips #0 screws on the bottom of the camera. Remove the five 30mm Phillips #0 screws on the bottom of the camera.
    • Remove the five 30mm Phillips #0 screws on the bottom of the camera.
  2. Use a plastic opening tool to disconnect the internal hinges that snaps the camera into place.
    • Use a plastic opening tool to disconnect the internal hinges that snaps the camera into place.
    • Using a plastic opening tool is important since a metal one will scratch or damage the thin plastic hinges that hold the camera together.
  3. It will still be connected by a plastic film. This can also be disconnected by pulling up the white part where it connects to the light circuit board.
    • It will still be connected by a plastic film. This can also be disconnected by pulling up the white part where it connects to the light circuit board.
  4. Take out the two 20 mm screws that attach it to the shutter.
    • Take out the two 20 mm screws that attach it to the shutter.
  5. Remove the ten 30 mm Phillips #0 screws from the front lens.
    • Remove the ten 30 mm Phillips #0 screws from the front lens.
  6. Take the shutter screen parts out of the lens.
    • Take the shutter screen parts out of the lens.
    • Now push out the front lens.
    • Slowly take out the shutter screen parts and lens, adding too much force will break them.
Abschluss
Jerry Hadjah
525 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 8-4, Botvin Spring 2016 Mitglied von UMass Dartmouth, Team 8-4, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G4
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 413
