Zum Hauptinhalt wechseln
Bell and Howell DNV16HDZ LED Replacement
Was du brauchst
  1. Bell and Howell DNV16HDZ LED Replacement, Lens Assembly: Schritt 1, Bild 1 von 2 Bell and Howell DNV16HDZ LED Replacement, Lens Assembly: Schritt 1, Bild 2 von 2
    • Remove the five 30mm Phillips #0 screws on the bottom of the camera.
  2. Bell and Howell DNV16HDZ LED Replacement: Schritt 2, Bild 1 von 1
    • Use a plastic opening tool to disconnect the internal hinges that snaps the camera into place.
    • Using a plastic opening tool is important since a metal one will scratch or damage the thin plastic hinges that hold the camera together.
  3. Bell and Howell DNV16HDZ LED Replacement: Schritt 3, Bild 1 von 1
    • It will still be connected by a plastic film. This can also be disconnected by pulling up the white part where it connects to the light circuit board.
  4. Bell and Howell DNV16HDZ LED Replacement, LED: Schritt 4, Bild 1 von 1
    • Take out the two 20 mm Phillips #0 screws that attach it to the shutter.
  5. Bell and Howell DNV16HDZ LED Replacement: Schritt 5, Bild 1 von 3 Bell and Howell DNV16HDZ LED Replacement: Schritt 5, Bild 2 von 3 Bell and Howell DNV16HDZ LED Replacement: Schritt 5, Bild 3 von 3
    • The two 30 mm Phillips #0 screws left can be removed to gain access to the circuit board along with the LED.
    • From here we can pop out the LED using the wedge or your fingers if you can manage it.
Abschluss
Donald Desrosier
101 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 8-4, Botvin Spring 2016 Mitglied von UMass Dartmouth, Team 8-4, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G4
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 288
