Zum Hauptinhalt wechseln
Einleitung
These are the first steps to taking apart the device.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the five 30mm Phillips #0 screws on the bottom of the camera. Remove the five 30mm Phillips #0 screws on the bottom of the camera.
    • Remove the five 30mm Phillips #0 screws on the bottom of the camera.
  2. Use a plastic opening tool to disconnect the internal hinges that snaps the camera into place.
    • Use a plastic opening tool to disconnect the internal hinges that snaps the camera into place.
    • Using a plastic opening tool is important since a metal one will scratch or damage the thin plastic hinges that hold the camera together.
  3. It will still be connected by a plastic film. This can also be disconnected by pulling up the white part where it connects to the light circuit board.
    • It will still be connected by a plastic film. This can also be disconnected by pulling up the white part where it connects to the light circuit board.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Jerry Hadjah
525 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 8-4, Botvin Spring 2016 Mitglied von UMass Dartmouth, Team 8-4, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G4
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 1
Insgesamt: 123
