Einleitung
If the glass door breaks, becomes damaged, or is too dirty for your liking, this easy and effective guide will walk you through the steps required to replace it.
Was du brauchst
Remove five 11.6 mm Phillips #2 screws from the rear of the device.
Remove one 21.9 mm Phillips #2 retaining screw from upper-middle portion of door frame.
Remove four 13.7mm Phillips #2 screws from black plastic feet to separate the cover from the device.
Unhook the black coil springs from back of the toaster on both sides of the device.
Use the black spudger to gently depress the hinge prongs on the bottom of the door.
