Zum Hauptinhalt wechseln
Bella 4-Slice Toaster Oven Glass Door Replacement
Was du brauchst
  1. Bella 4-Slice Toaster Oven Glass Door Replacement, Outer Shell: Schritt 1, Bild 1 von 1
    • Remove five 11.6 mm Phillips #2 screws from the rear of the device.
  2. Bella 4-Slice Toaster Oven Glass Door Replacement: Schritt 2, Bild 1 von 1
    • Open the front glass door of the toaster oven.
  3. Bella 4-Slice Toaster Oven Glass Door Replacement: Schritt 3, Bild 1 von 1
    • Locate retaining screw on the upper-middle portion of the door frame.
  4. Bella 4-Slice Toaster Oven Glass Door Replacement: Schritt 4, Bild 1 von 1
    • Remove one 21.9 mm Phillips #2 retaining screw from upper-middle portion of door frame.
  5. Bella 4-Slice Toaster Oven Glass Door Replacement: Schritt 5, Bild 1 von 1
    • Flip toaster onto back panel with feet facing forward.
  6. Bella 4-Slice Toaster Oven Glass Door Replacement: Schritt 6, Bild 1 von 1
    • Use spudger to pry the grey rubber inserts from the black plastic feet.
  7. Bella 4-Slice Toaster Oven Glass Door Replacement: Schritt 7, Bild 1 von 1
    • Remove four 13.7mm Phillips #2 screws from black plastic feet to separate the cover from the device.
  8. Bella 4-Slice Toaster Oven Glass Door Replacement: Schritt 8, Bild 1 von 1
    • Lift the black outer cover off of the toaster
  9. Bella 4-Slice Toaster Oven Glass Door Replacement, Glass Door: Schritt 9, Bild 1 von 2 Bella 4-Slice Toaster Oven Glass Door Replacement, Glass Door: Schritt 9, Bild 2 von 2
    • Unhook the black coil springs from back of the toaster on both sides of the device.
  10. Bella 4-Slice Toaster Oven Glass Door Replacement: Schritt 10, Bild 1 von 1
    • Use the black spudger to gently depress the hinge prongs on the bottom of the door.
  11. Bella 4-Slice Toaster Oven Glass Door Replacement: Schritt 11, Bild 1 von 2 Bella 4-Slice Toaster Oven Glass Door Replacement: Schritt 11, Bild 2 von 2
    • Gently slide door away from the device, removing it from the device.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 870
