Einleitung
If the heating element fails for any reason, and needs to be replaced, this guide will walk you through the simple steps required to replace the component.
Was du brauchst
Remove five 11.6 mm Phillips #2 screws from the rear of the device.
Remove one 21.9 mm Phillips #2 retaining screw from upper-middle portion of door frame.
Remove four 13.7mm Phillips #2 screws from black plastic feet to separate the cover from the device.
Use a metal spudger to unfold the tabs of metal that hold heating element in place.
Gently push the heating element from the side with the red wire to remove it from the toaster.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
