Einleitung
Removing the black metal outer shell of the toaster is an important first step in replacing most major toaster components. This easy-to-follow guide makes it easy to remove and replace.
Was du brauchst
Remove five 11.6 mm Phillips #2 screws from the rear of the device.
Remove one 21.9 mm Phillips #2 retaining screw from upper-middle portion of door frame.
Remove four 13.7mm Phillips #2 screws from black plastic feet to separate the cover from the device.
