Einleitung
If the temperature dial fails, just follow this simple guide to replace it and fix your toaster.
Was du brauchst
Remove five 11.6 mm Phillips #2 screws from the rear of the device.
Remove one 21.9 mm Phillips #2 retaining screw from upper-middle portion of door frame.
Remove four 13.7mm Phillips #2 screws from black plastic feet to separate the cover from the device.
Using a plastic spudger, gently pry the black plastic temperature dial away from the face of the toaster.
Remove two 5.91 mm #2 Phillips screws which secure the inner component to the toaster.
Inside the device, unplug the red wire connecting the black plastic part of the dial to the heating element.
