Einleitung
If the timer fails, it is easy to replace and fix your toaster using this guide.
Was du brauchst
Remove five 11.6 mm Phillips #2 screws from the rear of the device.
Remove one 21.9 mm Phillips #2 retaining screw from upper-middle portion of door frame.
Remove four 13.7mm Phillips #2 screws from black plastic feet to separate the cover from the device.
Using a plastic spudger, gently pry the black plastic timing dial away from the face of the toaster.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
