Einleitung
Use this guide to replace a faulty heating element in your Bella Pro Series Air Fryer TXG-FS075A.
The heating element of the air fryer is what creates the heat to cook the food in the air fryer. A failing heating element can cause the food to be uncooked or not cooked properly. In some cases, the element might not be heating up at all.
Before using this guide, make sure to review the trouble shooting Bella TXG-FS075A Troubleshooting guide here.
Was du brauchst
Remove the four 13 mm screws from the second plastic frame using a Phillips #2 screwdriver.
Pry off the black plastic frame.
Using a spudger, pry off the outer frame.
Pull up on the outer frame, exposing the inner wall of the fryer.
Remove the 13 mm screw connecting to the heating element's bracket using a Phillips #2 screwdriver.
