Einleitung
Use this guide to replace a faulty motherboard in your Bella Pro Series Air Fryer TXG-FS075A.
The motherboard of the air fryer is essentially the brain of the air fryer. A failing motherboard can cause a variety of problems such as the food not heating up correctly or the fryer not turning on. Before using this guide, make sure to review the troubleshooting guide here.
Was du brauchst
Remove the four 13 mm screws from the second plastic frame using a Phillips #2 screwdriver.
Pry off the black plastic frame.
Remove the two 13 mm screws from the base of the motherboard using a Phillips #2 screwdriver.
