Einleitung
Is your speaker not working but still holding a charge? It's probably your motherboard. Follow this guide to replace it.
Was du brauchst
Peel the rubber cover back from the corner of the speaker to reveal the screw.
Repeat for the three remaining corners.
Use the J1 bit attached to the screwdriver to remove the four 10mm screws from the bottom of the speaker.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
