Einleitung
Is your auxillary charging base no longer holding a charge. Dont forget the charging basics and follow this guide to replace your auxillary charger!
Was du brauchst
Peel the rubber cover back from the corner of the auxiliary charging base to reveal the screw.
Use the J1 bit attached to the screwdriver to remove the four 10mm screws from the bottom of the auxiliary charging base.
Using the tweezers, pull the wires from the auxiliary charging base's internal chip.
