Einleitung
Actions speak louder than words especially when your speaker's broken. Speak up and follow this guide.
Was du brauchst
Peel the rubber cover back from the corner of the speaker to reveal the screw.
Repeat for the three remaining corners.
Use the J1 bit attached to the screwdriver to remove the four 10mm screws from the bottom of the speaker.
Lift the bottom cover away from the rest of the speaker.
Using the tweezers, pull the wires from the speaker's internal chip.
Using tweezers remove excess glue that may be covering the screw holes of the speaker's driver.
Using the metal spudger, pry up on the speaker's base.
Pull the wire from the speaker's driver's base from the hole it was in.
