Zum Hauptinhalt wechseln
Besta Super 5000 Keyboard Replacement
Was du brauchst
  1. Besta Super 5000 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the device over so that the barcode is facing upwards.
  2. Besta Super 5000 Keyboard Replacement: Schritt 2, Bild 1 von 2 Besta Super 5000 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Place your fingers on the battery cover arrow and pull the cover down and off the device.
  3. Besta Super 5000 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Pull upwards on the battery tab to remove the battery from the device.
  4. Besta Super 5000 Keyboard Replacement, Back Cover: Schritt 4, Bild 1 von 1
    • Remove the five screws around the edge of the device using a Phillips #0 screwdriver.
  5. Besta Super 5000 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Remove the two screws behind the battery using a Phillips #0 screwdriver.
  6. Besta Super 5000 Keyboard Replacement: Schritt 6, Bild 1 von 2 Besta Super 5000 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Potential for device damage: All screws must be removed before you begin this step. Do not forcefully pry apart the device with screws still in it because you may damage it.
    • Gently pry off the backing using an opening tool.
  7. Besta Super 5000 Keyboard Replacement, Motherboard: Schritt 7, Bild 1 von 1
    • Remove the three silver screws from the black round battery using a Phillips #0 screwdriver.
  8. Besta Super 5000 Keyboard Replacement: Schritt 8, Bild 1 von 1
    • Remove the five small screws from the motherboard using a Phillips #0 screwdriver.
  9. Besta Super 5000 Keyboard Replacement: Schritt 9, Bild 1 von 3 Besta Super 5000 Keyboard Replacement: Schritt 9, Bild 2 von 3 Besta Super 5000 Keyboard Replacement: Schritt 9, Bild 3 von 3
    • Using a pair of tweezers, pinch the center of the yellow ribbon located in the corner of the device.
    • Potential for device damage: Do not yank or remove the ribbon from the device.
    • Carefully pull the hidden piece of yellow ribbon out from underneath the motherboard.
  10. Besta Super 5000 Keyboard Replacement: Schritt 10, Bild 1 von 2 Besta Super 5000 Keyboard Replacement: Schritt 10, Bild 2 von 2
    • Potential for device damage: All screws must be removed before you begin this step. Do not forcefully pry apart the motherboard with screws still in it because you may damage it.
    • Carefully pry off the motherboard with an opening tool.
  11. Besta Super 5000 Keyboard Replacement: Schritt 11, Bild 1 von 1
    • Take the motherboard out of the body frame.
  12. Besta Super 5000 Keyboard Replacement: Schritt 12, Bild 1 von 2 Besta Super 5000 Keyboard Replacement: Schritt 12, Bild 2 von 2
    • Lift the black keyboard mat off of the motherboard.
    • Replace the motherboard.
  13. Besta Super 5000 Keyboard Replacement, Keyboard: Schritt 13, Bild 1 von 1
    • Replace the old keyboard mat with a new keyboard mat.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Sarah
138 Reputation
1 Anleitung geschrieben
Ohio State, Team 1-5, Buehl Fall 2014 Mitglied von Ohio State, Team 1-5, Buehl Fall 2014
OSU-BUEHL-F14S1G5
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 18
Insgesamt: 242
